Can LastPass be instructed to ignore a specific field?
Postby katogeek » Tue Jul 02, 2019 10:51 am
My organization uses two-step sign-in, where you first log in with your username/password, then on the next screen you enter a number from an authenticator app.
Each time I enter the one-time number, LastPass thinks it's a password change and prompts me to update the password in the database.
One time I accidentally clicked "update" and then had to fight with IT to reset my password since LastPass now "forgot" my actual password.
Can I tell LastPass to ignore the "password" field on the two-step auth page, but still fill in my actual password on the main username/password page?
katogeek
Re: Can LastPass be instructed to ignore a specific field?
Postby shanepierce1 » Wed Jul 03, 2019 2:26 pm
katogeek Wrote:My organization uses two-step sign-in, where you first log in with your username/password, then on the next screen you enter a number from an authenticator app.
I also have the same question. An answer is appreciated.
Thanks and Regards,
Shane
shanepierce1
Postby shanepierce1 » Sat Jul 13, 2019 3:21 pm
One time I accidentally clicked "update" and usps tracking then had to fight with IT to reset my password since LastPass now "forgot" my actual password.
Still no answer. Help is highly appreciated.
Thanks in advance.
Regards,
Shane
shanepierce1
Users browsing this forum: Google Feedfetcher and 29 guests
