No auto-filling of fields in LastPass?
Postby daniel303 » Wed May 15, 2019 9:01 am
When I open a page known to LastPass it shows me that it has the respective data, but it doesn't put the data into the fields automatically.
Instead I have to click in order to make LastPass enter the data into the fields.
Is there a way to enable automatic filling of data as most (all?) other password managers do it?
daniel303
Re: No auto-filling of fields in LastPass?
Postby SpyrosGr » Wed Sep 11, 2019 11:41 am
Hi, daniel303
If you are still facing the same problem, click LP icon>Account Options>Extension Preferences and under 'General' make sure that 'Automatically Fill Login Information' is enabled. Furthermore, check that the 'Disable Auto fill' check box in 'Advanced Settings' of your item is clear.
Regards
SpyrosGr
Postby Excalibur201 » Sun Sep 29, 2019 8:31 pm
Hi, same issue. Just started happening recently using Chrome, maybe a couple weeks.
1) Under Account Options - Extension Preferences - General:
- Automatically fill login information" is CHECKED
2) Under the site settings (checked a few), the defaults are checked:
Require Master Password Reprompt - UNCHECKED
Autologin - UNCHECKED (but tried checking, still doesn't fill fields or autologin)
Disable Autofill - UNCHECKED
Why are none of my forms filling? instead, I have to manually click the little Lastpass icon that appears in the right of each field, then click it to get it to fill.
What's going on???
Excalibur201
Users browsing this forum: MSN [Bot], yojaba4600974 and 56 guests
