Restrict Security Challenge
Postby darn0626608 » Fri Jan 18, 2019 7:15 am
Is there anyway to stop sites being included from the Security Challenge? For example, my library issue a barcode and a four digit code to be entered into the barcode reader. It currently has be to a four digit code and LastPass will always highlight it as weak.
darn0626608
Re: Restrict Security Challenge
Postby FlyingHawk » Fri Jan 18, 2019 12:23 pm
This request pops up quite a few times, but honestly I don't understand why people want this. If you see a weak password on a site, you check if it's expected/unavoidable, if it is, then you just move on. Why do you want to exclude them?
FlyingHawk
Postby darn0626608 » Fri Jan 18, 2019 12:29 pm
In my case, because it's one of four that I can't do anything about and that situation is unlikely to change. Therefore it's a waste of my time and system time.
If it "pops up quite a few times" I guess that means there is no solution.
darn0626608
Postby FlyingHawk » Fri Jan 18, 2019 12:43 pm
darn0626608 Wrote:because it's one of four that I can't do anything about and that situation is unlikely to change.
I know. That's why I said if it's unavoidable you just move on.
darn0626608 Wrote:Therefore it's a waste of my time and system time.
You see them then ignore them. How much time does it take really? Less than a second I guess. "System time" is even more negligible.
I suspect it's more of a obsession with a clean record rather than a matter of "time wasted" that makes people want this option. However, I still think it's beneficial to have a constant reminder that some of my passwords are objectively weak, even if I can't do anything about them.
darn0626608 Wrote:I guess that means there is no solution.
Correct. There's no option to do this.
FlyingHawk
Users browsing this forum: No registered users and 69 guests
