Clear Clipboard after use
Postby eXtreme51 » Mon Jan 07, 2019 2:51 am
Hello,
I've installed LastPass and there's one feature missing from Chrome: Clear Clipboard after use.
I've tried installing it, re-installing it from Chrome Store but nothing works.
I only have this feature available in Firefox, under advanced preferences.
Feature is also missing from Edge.
Can you please help me?
What did I overlook?
Thanks.
eXtreme51
Re: Clear Clipboard after use
Postby FlyingHawk » Mon Jan 07, 2019 12:18 pm
I believe you need to install the binary component for this to work.
FlyingHawk
Postby eXtreme51 » Mon Jan 07, 2019 12:21 pm
Hi,
I've tried but that didn't work. Unless I'm missing something...
eXtreme51
Postby eXtreme51 » Wed Jan 09, 2019 7:17 am
Anyone?
eXtreme51
Postby eXtreme51 » Fri Jan 25, 2019 9:16 am
Hi, I've figured it out so I thought it'd best to let you know what I did.
1. Click on the extension using Google Chrome
2. Click 'Account Options'
3. Click 'About LastPass'
4. You will see a status of 'Binary Component: false' and a button next to it that says 'Enable Native Messaging'
5. Click 'Allow for the security prompt.
6. Restart Chrome
And that's it. Clear clipboard option is now available at the extension options, under 'Advanced'.
eXtreme51
Postby FlyingHawk » Fri Jan 25, 2019 12:36 pm
I'm interested in what you did before when you said "I've tried but that didn't work".
How else were you installing the binary component (and failed)?
FlyingHawk
Postby eXtreme51 » Fri Jan 25, 2019 12:43 pm
Well, according to the documentation, I was told to install the 'binary' version of LastPass, which I did, but nothing happened afterwards.
It wasn't mentioned ANYWHERE (also not by you) that it will be disabled by default and that I have to go to 'About' and click 'Enable Native Messaging' (which has no literal nor figurative connection to 'Enable binary').
eXtreme51
Postby FlyingHawk » Fri Jan 25, 2019 12:58 pm
In my experience, the binary installer would automatically reinstall the extension in Chrome and make the settings right. Perhaps it's a different version.
FlyingHawk
Postby eXtreme51 » Fri Jan 25, 2019 1:02 pm
I even tried to install it from the store after reading that some settings/permissions might have changed but that didn't do it either.
I'm just happy it works now because it was somewhat frustrating.
Thank you for your help!
eXtreme51
Users browsing this forum: Google Feedfetcher and 75 guests
