Disable History
Disable History
Postby Dux » Thu Jan 03, 2019 9:22 pm
Hello,
I would like lastpass stop tracking "my recent history", without success.
So far, I tried:
- Account Settings > General > Show Advanced Settings > Privacy > uncheck the option, "Keep track of login and Form Fill history" then click Update
- LastPass Icon > Preferences > Advanced, and select "0" as the number of sites for your recently used list.
Both didn't work.
Any ideas?
Thank you very much!
Dux
Disable History
Postby Dux » Thu Jan 03, 2019 9:28 pm
Hello,
I've been trying to desable "my recent history" feature from the vault, without much success.
So far, I tried:
- Account Settings > General > Show Advanced Settings > Privacy > uncheck the option "Keep track of login and Form Fill history"
Any ideas?
Thank you, very much
Dux
Re: Disable History
Postby sanctempdyra712 » Fri Jan 04, 2019 7:17 am
I tried my best. But only these two options are availble to remove history. Try 2-3 times on continues base. Hope it will then stay as it is.
sanctempdyra712
Users browsing this forum: sgilmo and 57 guests
