Login with bash script into laspass-cli
Postby houghi » Sun Dec 16, 2018 10:33 am
Is there a way to use a bashscript (or other method via Linux CLI) to login with lpass without the need to manually enter the password?
That way I can easily use it with bash scripts without the need to have the passwords locally.
Yes, I am well aware of the risks.
houghi
Re: Login with bash script into laspass-cli
Postby RevHokan » Tue Jan 08, 2019 1:13 pm
I use a line something like this a provide a password for my email client:
export imap_pass="`/usr/local/bin/lpass show --password $lpass_prefix$imap_user@$from_hostname`"
where $imap_user is my email username (before the "@" and $from_hostname is my email adderess hostname.
I then use $imap_pass as my login password.
RevHokan
Postby houghi » Tue Jan 08, 2019 8:43 pm
Thanks for answering.
I think I was not clear. With this method I would still need to enter the master password.
houghi@small : lpass show --password general
Error: Could not find decryption key. Perhaps you need to login with `lpass login`.
houghi@small : lpass login <LOGIN NAME>
Success: Logged in as <LOGIN NAME>
password
houghi@small :
So I would still need to give the master password.
I do have found a way. I DO ADVICE AGAINST IT. DO NOT USE THIS!
1) Make a script that will show the password (Told you not to do this)
This can be just an echo or anything else.
2) Set the LPASS_ASKPASS environment variable to the script.
3) "lpass login username" will now work.
4) Do not use this as this is extremely unsafe
houghi
Users browsing this forum: Google [Bot] and 34 guests
