Firefox Extension won't open
Postby doctorjellybean195 » Thu Mar 29, 2018 3:38 pm
Clicking on the LastPass extension in Firefox doesn't launch anything. See linked screenshot
https://ibb.co/j8PV27
doctorjellybean195
Re: Firefox Extension won't open
Postby jpenny84 » Thu Mar 29, 2018 4:24 pm
If you are in incognito mode, access the menu from the main browsing window. Otherwise try removing and reinstalling the extension.
jpenny84
Postby doctorjellybean195 » Thu Mar 29, 2018 4:28 pm
I'm not in incognito mode (that I'm aware of), but removing and reinstalling the extension did the trick. Thanks.
doctorjellybean195
Postby dahlgren » Thu Mar 29, 2018 6:01 pm
The same behavior (exactly as seen in the screenshot) is happening to me in Waterfox version 56.0.4
The behavior just appeared today.
dahlgren
Postby SIMJEDI » Thu Mar 29, 2018 9:53 pm
Also using WaterFox and having problems. Had to revert back to version 4.7.1 where it still works.
SIMJEDI
Postby jpenny84 » Thu Mar 29, 2018 9:55 pm
While Waterfox is based on Firefox, it is not a supported browser.
https://lastpass.com/support.php?cmd=showfaq&id=8886
jpenny84
lastpass drop down box not showing in firefox
Postby kenhallUkulele » Fri Mar 30, 2018 3:08 am
Last pass seems to be ok on my menu bar in Firefox the icon has gon red to show that I am logged in, but when I click it instead of opening the drop down menu box all i get is a little arrow under the lastpass icon and whatever I do I cannot get the lastpass menu to drop down. this has only just started happening I have bee using Lastpass with no problems for years. Pleas help.
kenhallUkulele
Postby tpg0007306 » Fri Mar 30, 2018 8:13 am
I've the same issue! Started happening 3/29 on FF 56.0.2.
My workaround is to turn on the full pane login screen in addon options and use CTRL+ALT+H to access the vault. The latter is very finicky sadly.
tpg0007306
Postby tpg0007306 » Fri Mar 30, 2018 9:41 am
This is a very strange bug because it doesn't block ALL LastPass popups, just the the one triggered by pressing the button. Like if you get prompted to add a site, you can edit that popup in the upper right like normal.
tpg0007306
Postby jpenny84 » Fri Mar 30, 2018 9:44 am
Try removing and reinstalling the extension.
jpenny84
Users browsing this forum: cms123 and 94 guests
