Chrome javascript error - onloadwff.js:68
Postby booji » Thu Sep 28, 2017 2:34 pm
I'm getting a Javascript error from the chrome pugin on Windows.
The error is on a website I'm developing, so isn't yet publicly accessible.
It's a bootstrap 4 UI, on a modal for changing your password.
The form has three fields: old password, new password, confirm new password.
If you enter the old password incorrectly and submit, the server responds with a 403 error, and an alert is inserted into the UI.
At that point, Lastpass starts throwing this error every second or so:
Uncaught TypeError: o.val is not a function
at n (onloadwff.js:68)
at r (onloadwff.js:68)
at onloadwff.js:68
It repeats over and over, with no indication that it ever stops happening.
booji
Re: Chrome javascript error - onloadwff.js:68
Postby che3ver » Tue Oct 03, 2017 9:45 pm
I have the exact same error, also on a site I'm developing. I'm using the chrome plugin on a Mac.
My error is happening after a successful ajax call (201) for my registration. I'm using Angular.
It doesn't seem to prevent the rest of my javascript from continuing to run.
che3ver
Postby che3ver » Tue Oct 03, 2017 9:54 pm
Update: I fixed this error by renaming the ids of my fields to reg_username, reg_password, login_username, and login_password.
che3ver
Postby rbrunt158 » Thu Oct 05, 2017 10:56 am
Adding a pw change to a site i'm doing and keep getting this error as well. Changed around the id's but the only thing that stops this is disabling lastpass. Also using angular.
rbrunt158
Postby totallyahuman » Fri Oct 06, 2017 9:19 am
che3ver Wrote:Update: I fixed this error by renaming the ids of my fields to reg_username, reg_password, login_username, and login_password.
Did you change it from reg_XYZ to login_XYZ, and that fixed the issue?
Please report this bug if you haven't already (this is just the support section). That's a pretty silly and quite annoying bug, and means that arbitrary users can end up being caught in infinite loops just because of choice of ID value. :/
totallyahuman
Postby Andrea » Tue Oct 31, 2017 6:43 am
Any news about it? Lastpass support team seems to ignore the bug. I'm building a very simple update password form (with Angular) where there are 3 inputs for: currentPassword, newPassword and confirmPassword. Once the form is submitted (via ajax) it start to fire an infinite loop of errors in console (onloadwff.js:68 Uncaught TypeError: o.val is not a function). It is really annoying and should be fixed as soon as possible. If there is a workaround please let us know the solution and we will implement it in our forms. Thanks.
Andrea
Postby tmstark586 » Sat Feb 10, 2018 8:08 am
This needs to be fixed. It's breaking my software for people who use lastpass. Unacceptable.
tmstark586
Postby berglion » Tue Mar 06, 2018 6:19 am
Completely agree. Can't workaround by changing ids.
berglion
Postby chris732 » Tue Mar 06, 2018 11:41 pm
This needs to be escalated.
chris732
Postby danspam » Thu Mar 15, 2018 1:25 am
Experiencing this issue too. Please fix!
danspam
Users browsing this forum: Majestic-12 [Bot], vesqute and 51 guests
