LastPass extension corrupted, crashes Chrome
Re: Chrome extension corrupted - reinstall/repair dont work
Postby edmayer813 » Sat Aug 05, 2017 5:37 pm
I uninstalled Chrome and re-installed it again since other extensions show as corrupted as well (i.e. Norton extensions). Chrome worked good for a few days but the issue popped up again for LastPass and other extensions.
I am thinking to use LastPass www to login instead the Chrome extension.
edmayer813
Postby ivankonanykhin120 » Fri Aug 18, 2017 9:01 pm
LastPass extension corrupted, crashes Chrome every time. System: freshly installed Ubuntu, all packages updated, no fiddling. On a different machine with older Ubuntu and older Chrome the extension works fine.
ivankonanykhin120
Re: LastPass extension corrupted, crashes Chrome
Postby reed » Sat Aug 19, 2017 2:51 am
Having the same problem here. Exactly the same setup as OP.
reed
Chrome extension 4.1.63 inop on Samsung Chromebook Pro
Postby lisa953 » Sat Aug 19, 2017 2:11 pm
Request investigation and resolution. Thank you in advance.
Extension crashes after installation and subsequent existing account login (after showing the vault ever so briefly) on Samsung Chromebook Pro:
Google Chrome OS Version 60.0.3112.101 (Official Build) (64-bit)
Platform 9592.82.0 (Official Build) stable-channel caroline
Firmware Google_Caroline.7820.300.0
Channel Currently on stable
Build Date Friday, August 11, 2017
Error message on extension page:
LastPass: Free Password Manager 4.1.63
This extension may have been corrupted.
Repair does NOT resolve.
Deletion/re-installation does NOT resolve.
lisa953
Chrome extension 4.1.63 inop on Sector5 Chromebook
Postby lisa953 » Sat Aug 19, 2017 2:21 pm
Extension crashes after installation and subsequent existing account login (after showing the vault ever so briefly) on Sector5 Chromebook:
Google Chrome OS Version Version 61.0.3163.51 (Official Build) dev (32-bit)
Platform 9765.31.0 (Official Build) dev-channel veyron_mighty
Firmware Google_Veyron_Mighty.6588.197.0
Build Date Thursday, August 17, 2017
lisa953
Postby jsterling8643 » Sat Aug 19, 2017 2:33 pm
Exact same issue. Brand new Dell XPS 13. Freshly reformated with Ubuntu 16.04. Installed latest Chrome. LastPass plugin says it's corrupted. I click "Repair" and it reinstalls, I enter my username/password/2fa, it briefly opens then crashes. I check the extensions tab again, and again it says corrupted. Same issue if I fully uninstall it, then reinstall it. I've tried with a fresh Chrome profile too with no luck.
jsterling8643
Postby benjaminbritcliffe841 » Sat Aug 19, 2017 2:39 pm
Same issue on a chromebook, found a workaround, it seems to be corrupting it when it automactically open the vault on login, close the auto tab before it loads to avoid corruption. Why is it doing this though?
Re: Chrome extension 4.1.63 inop on Samsung Chromebook Pro
Postby marcoisella442 » Sat Aug 19, 2017 3:47 pm
Exactly the same behaviour.
Freshly installed ubutnu 17.04 + chrome Version 60.0.3112.101 (Official Build) (64-bit) + LastPass: Free Password Manager 4.1.63
lisa953 Wrote:Request investigation and resolution. Thank you in advance.
marcoisella442
Postby mrkbrwn738 » Sat Aug 19, 2017 5:24 pm
same here on a fresh install
mrkbrwn738
Postby NP » Sat Aug 19, 2017 10:34 pm
Same problem on Ubuntu 16.04 LTE Chrome installation.
NP
Users browsing this forum: Google Feedfetcher and 62 guests
