Cannot pair my Yubikey with Lastpass
Postby svensven » Fri Oct 16, 2015 5:53 am
Hi
I do have a Lastpass premium account and have some problems to pair my Yubikey Standard with Lastpass.
When I'm following the instructions going into two-factor tab in lastpass and focus on "Yubikey #1" filed and push the button on my key, the string does not get filled.
When using the key with other accounts the key lights up when it can be pushed, but not in this case.
Tried both on my Mac and Windows PC.
Regards
Sven
svensven
Re: Cannot pair my Yubikey with Lastpass
Postby bose86 » Sat Oct 17, 2015 7:48 pm
Hi,
I am encountering this exact same issue. The Yubikey works fine with my Google account, but not with Lastpass Premium. What gives? Max OSX Yosemite, Chrome.
Thanks,
D
bose86
Postby svensven » Mon Oct 19, 2015 3:12 am
Using it for my Google account as well, but with Lastpass it seems to be a problem.. :/
svensven
Postby jl818 » Fri Oct 23, 2015 12:11 am
I also have a Yubikey Neo which I use with several other accounts -- the key works. But when I follow the instructions for setting it up with my Lastpass account, nothing happens when I tap the key with the cursor active in the field. No dots appear.
jl818
Postby josh225 » Fri Oct 23, 2015 11:10 am
I'm seeing the same issue, using OS X 10.10.5, in both Chrome and Safari. My YubiKey works just fine with Github, but LastPass appears to be ignoring it.
josh225
Postby antman313 » Sat Oct 24, 2015 6:55 pm
since today my yubikey edge isn't seen anymore. so i cant login into lp with my OTP. If i want to register it again now the following error is comeing.
An error occurred.
At least one of the YubiKey tokens provided failed to validate.
with all my other accounts my yubikey with OTP and two factor auth is working well. but now here not.
i use chrome, windows 8.1, yubikey edge (newest version, bought for 14 days over amazone.de)
any idea?
thanks
andy
antman313
Postby alessandro327 » Sat Oct 31, 2015 2:59 pm
Same problem here!
alessandro327
Postby alessandro327 » Sat Oct 31, 2015 3:05 pm
Same problem here!
alessandro327
Postby nyarbrough968 » Tue Dec 01, 2015 9:38 am
Same problem here a month later. This is the only page that shows up in Google... :(
nyarbrough968
Postby nyarbrough968 » Tue Dec 01, 2015 8:23 pm
For the win! :)
Jed @ LastPass Support Wrote:Thank you for contacting LastPass Support.
You need to set your YubiKey configuration to OTP authentication mode:
http://www.yubico.com/products/services ... bikey-otp/
Once that is done, visit the following URL: https://lastpass.com/debug.php and where it says 'YubiKey with LastPass', run the authenticator to make sure everything is working properly.
If no issues found, try to setup the YubiKey once again:
https://helpdesk.lastpass.com/security- ... ntication/
Let me know how it goes.
Best,
Jed
nyarbrough968
Users browsing this forum: Google Feedfetcher, larrymcj1 and 44 guests
