Can't register my YubiKey
Postby iam226 » Fri Jul 24, 2015 1:41 pm
I have some trouble to register my YubiKey with Lastpass.
I go to my settings and click Multifactor options. I then click the edit button to enter the settings of my Yubico YubiKey. I switch Enabled to Yes and push on the YubiKey after i clicked on the field of YubiKey #1. My password gets filled in and then i push Update. Then i get the following error:
An error occurred.
At least one of the YubiKey tokens provided had an incorrect length.
Any help?
iam226
Re: Can't register my YubiKey
Postby iam226 » Sat Jul 25, 2015 8:05 am
I have this fixed....wanted to do it with static password, but it needed to be OTP
iam226
Postby dcurtis74235 » Fri Apr 01, 2016 5:20 pm
I am getting this message An error occurred.
At least one of the YubiKey tokens provided had an incorrect length but I don't understand how to correct it. I found a post that refers to OTP, but again, I'm not sure of the significance - do you have any suggestions?
Thanks!
dcurtis74235
Postby kirwan457 » Fri Oct 14, 2016 8:42 am
I see the same error. I have a YubiKey 4 which is listed as supported.
kirwan457
Postby jpenny84 » Fri Oct 14, 2016 11:31 am
Make sure the YubiKey is configured not to use U2F:
https://lastpass.com/support.php?cmd=showfaq&id=8126
jpenny84
Postby Badcustomersupport » Fri Nov 30, 2018 10:51 pm
Yep, I also have this issue and support was unwilling up until now to help. This with a “premium subscription”’ I’m very disappointed at the moment. I wonder if another password manager works or is it just a last pass issue.
Good luck!
Badcustomersupport
Postby acarheden » Sat Jul 13, 2019 12:03 pm
Confirmed that this is STILL an issue in mid 2019. My yubikey is and older black one, so it's not the U2F issue. If they don't support certain yubikeys, the should give you info in the UI about how to tell if a particular yubikey will work.
acarheden
Postby Bex » Mon Jul 15, 2019 12:28 pm
acarheden Wrote:Confirmed that this is STILL an issue in mid 2019. My yubikey is and older black one, so it's not the U2F issue. If they don't support certain yubikeys, the should give you info in the UI about how to tell if a particular yubikey will work.
Hi,
Can you please confirm which Operating system and device you are experiencing this issue on?
Bex
Site Admin
Users browsing this forum: Google [Bot] and 33 guests
