viewtopic.php?f=6&t=143245#p476065viewtopic.php?f=12&t=149875&p=499905&hilit=suggested+folders#p499905To paraphrase Henry Ford, you can have any default folder you want, as long as it’s named (none).
Seriously, though, I think your plaint is similar to the above links which I provide for background info. As this forum is primarily a user/user forum, a more effective course of action may be to repost in the Feedback forum at
viewforum.php?f=1. (Can’t hurt. I can’t see that anyone else ever brought up this matter there.)
I’m not sure what your desire is, but it seems that you want all sites in a default folder of your choice. To that end, you may temporarily (until LP provides a disable switch as a result of your post
) derive a modicum satisfaction in naming a folder “1. Foldername” and using that as your primary folder. Since Folders are sorted numalpha, this will assure that it appears at the top of the vault list (after Favorites, Recently Used, & (none), if populated).
