comodo and lastpass install
Postby autofocus » Sun Jun 14, 2009 7:01 am
after using extension i decided to use installer based application as well but when i tried to install comodo firewall kept asking that this program is trying to control other applications , so i aborted the installation.
is it normal?
i am using keepass along with lastpass Firefox installation.
what are the benefits of standalone applications?
thanks
autofocus
Re: comodo and lastpass install
Postby JoeSiegrist » Sun Jun 14, 2009 10:54 am
lastpass.exe installs the IE plugin, and helps you get/remove passwords from IE and Firefox. It is normal that we 'control' other applications, those applications are IE and Firefox...
Postby autofocus » Mon Jun 15, 2009 6:23 pm
thanks for the reply.
i was concerned because when i started installing it wanted to take control of every application/process running on my system and comodo suggested that it is malware like behavior, so i aborted the installation.
thanks.
autofocus
