Coordinate LP App and Online
Postby CWBillow » Thu Dec 27, 2012 9:27 pm
I had asked about this issue once prior [ viewtopic.php?f=11&t=83792&p=277670&hilit=Billow#p277670 ].
What I'm having an issue with is that I go in and edit the Name of a given passcard, but the change isn't showing in the App. I set the refresh time to 5 minutes, I have gone offline and unloaded LP App, but the sync still isn't showing.
What am I missing here that I need to do?
Regards,
Chuck Billow
CWBillow
Re: Coordinate LP App and Online
Postby jpenny84 » Thu Dec 27, 2012 10:15 pm
If you're editing the site entry in your browser, are you either logging out of it, or refreshing (LastPass button > Tools > Refresh Sites) before refreshing and checking the desktop app?
jpenny84
Postby CWBillow » Thu Dec 27, 2012 10:24 pm
Yes, I did refresh online. I don't see any refresh for the desk App, but I did unload it and reload.
CWBillow
Postby CWBillow » Thu Dec 27, 2012 10:42 pm
Here's a bit of an update:
If I go to "My LastPass Vault" via right-clicking the App icon in my tray [right-click / Sites] my list is showing
2 Entry A
2 Entry B
Entry C
All these in fact have similar labels in my vault
In the App Vault they are showing as
2 Entry A
2 Entry B
2 Entry C
And then in my browser vault AND the listing in the browser icon "Sites" they show as
1 Entry A
2 Entry B
2 Entry B
It is this last group that are as they should be. Since all the entries contain much the same text labels, I added the numbers to prioritize the entries. But that only works if they sync properly!
CB
CWBillow
Postby CWBillow » Fri Dec 28, 2012 12:19 am
I got this fixed -- at least it APPEARS so. I uninstalled the LP App, and re-installed, and now it seems fine and all seem to match up.
Thanks,
Charles Billow
CWBillow
