Re-Install Again??
Re-Install Again??
Postby CWBillow » Sun Dec 16, 2012 8:05 pm
I have received the following error three times today...how can I fix it so that I resolve this definitely?? -- Especially since I'm not USING IE as my browser!
Regards,
Chuck Billow
"LastPass memory check failed. It is recommended that you reinstall the software application and the IE plugin"
CWBillow
Re: Re-Install Again??
Postby jonat » Mon Dec 17, 2012 10:43 am
I would ignore the reference to IE and perhaps wonder if there's something wrong with your PC. But do try an uninstall and reinstall and see what happens.
jonat
Postby CWBillow » Mon Dec 17, 2012 11:56 am
I did/do. It fixes it, till the next time. Although I use Firefox as my default, there are sites and times when IE is needed, and then, LP isn't working correctly. So I can't really "ignore it."
CWBillow
Postby Agent88 » Tue Dec 18, 2012 11:35 am
Why not boot an IE9 browser, install the LastPass plugin for IE9, and then exit IE9 and return to using Firefox? Then if you ever need IE9, it should work for you. Am I missing something here?
Agent88
