How can you tell if you have Pro
Postby BobSnow » Tue Dec 04, 2012 8:39 pm
How can you tell if you have Pro as you look at the Vault?
BobSnow
Re: How can you tell if you have Pro
Postby Lars » Tue Dec 04, 2012 8:55 pm
You can't.. but go to their site, more particularly this address: -- https://lastpass.com/my.php -- for details about your account status.
Lars
Postby BobSnow » Thu Dec 06, 2012 5:13 pm
Thanks Lars. I do have it. Where can I find an advantage. The manual is little help when I search on Pro.
Bob
BobSnow
Postby Lars » Thu Dec 06, 2012 5:22 pm
BobSnow Wrote:Thanks Lars. I do have it. Where can I find an advantage. The manual is little help when I search on Pro.
Bob
The only difference between Premium and non-Premium, is the ability to use LastPass on smartphones and other portable devices. Also, you'll get higher priority when seeking support.
Lars
