Just installed LastPAss, no red icon visible in the task bar
Postby MSwhip » Tue Dec 13, 2011 9:50 am
Why is it not showing as the video says it would?
Mine is missing, no grey or red icons, just totally absent
How do I make it visible?
Thank you
MSwhip
Re: Just installed LastPAss, no red icon visible in the task
Postby Israel » Tue Dec 13, 2011 12:29 pm
What browser are you using? It won't show up in your windows taskbar - it shows up in the browser toolbar.
Israel
Site Admin
Postby rikgolf » Fri Dec 23, 2011 1:13 pm
I opened up IE to my standard home page.When I tried to install the LS toolbar, I chose the LastPass toolbar in the toolbar drop down menu but when I clicked on it a box came up asking me if I wanted to disable it (even though it wasn't checked). IE must have thought it was already enabled but it wasn't appearing. I went to my vault and entered bing.com through the address bar. When the site came up so did the toolbar. Go figure.
rikgolf
Postby greenmoonart » Tue Jun 19, 2012 12:09 pm
I am using Firefox 13 and Chrome 19 and the icon has disappeared from both browsers.
greenmoonart
Postby Dlocks » Tue Jun 19, 2012 3:41 pm
I have the same problem with IE8 plus Windows 7. Today I received the notification about the update and after installing the update in some website the red (or grey) icon is not visible in the toolbar (and right mouse click on page => lastpass => doesn't show options) and on other site it is visible (including right mouse click menu).
I already removed the latest version, downloaded it from the website and installed it again and rebooted. Didn't help...
I have multiple tabs open and on the following sites I see the icon (and right click menu):
https://www.clickbank.com/login.htm
https://7search.com/scripts/advertiser/v3/login.aspx
While on the sites below the icon is not visible during the same browsersession:
https://adcenter.microsoft.com/?mkt=en-us
http://lastpass.com/index.php
When I go to "my lastpass safe" via the red icon I see the message "Please Enable Your LastPass Internet Explorer Browser Plugin" with instruction on how to enable it. However, it is alread enabled.
Dlocks
Postby Dlocks » Wed Jun 20, 2012 2:01 pm
I just downgraded to version 1.9 (Internet Explorer + Firefox + Chrome installer) and it is working again like how it should be working.
You can find older versions on the following page:
https://lastpass.com/releases/?a=1
Dlocks
Postby Agent88 » Fri Jun 22, 2012 1:27 pm
Same problem here. I think it is an issue with the 64bit browsers (at least in IE9). I have v1.9 working with IE9/32bit, but v2.0 will not work with IE9/64bit. Have not had time to install v.20 on IE9/32bit.... and don't want to take on more problems if it doesn't work...
Agent88
Postby Dlocks » Fri Jun 22, 2012 2:11 pm
I use 32-bit version of IE8. So it is not a specific 64-bit problem.
Dlocks
Postby jmparret » Sat Jun 23, 2012 3:13 pm
Just reboot. I installed the new version and IE worked fine but firefox nothing. I tried a few things with no success, then I hit restart and the red badge magically showed up.
Joe
jmparret
Postby Agent88 » Sat Jun 23, 2012 7:55 pm
jmparret Wrote:Just reboot. I installed the new version and IE worked fine but firefox nothing. I tried a few things with no success, then I hit restart and the red badge magically showed up.
Joe
Nope. This does not work for me. My IE9/32bit works fine with LP1.9, but my IE9/64bit with LP2.0 does not and I have rebooted several times.
Agent88
