IE9 64-bit: Vault will not display
Postby Tom H » Fri Jul 08, 2011 5:53 pm
I cannot access my vault listing in IE 9 (it's blank). It will accept my log in info, but does not display any of my sites, even if I search a site. I have run the manual installer (http://www.lastpass.com/dl) that's listed in Israel's posted reply to the same problem on 4/11/11, but still cannot view my vault sites. I believe I also had the same problem with IE8.
I can access individual sites/secure notes through the drop-down menu on the LastPass toolbar.
Per IE Manage Add-ons, version is 1.73.0.0 for LastPass Toolbar and LastPass Browser Helper Object. Also shown separately as "Not Available" publisher is "LastPass" It is enabled, but IE doesn't list a version number or a file location.
Tom H
Re: IE9 64-bit: Vault will not display
Postby st0rmcrow » Sat Jul 09, 2011 9:30 am
I would suggest you move to a more secure, compatible and better supported web browser.
Firefox http://www.mozilla.com/en-US/firefox/fx/ is a class example, along with Google's Chrome http://www.google.com/chrome/.
st0rmcrow
Postby DrD48 » Mon Sep 26, 2011 9:19 am
If you dont want to do this and have internet access, just go through the start menu, LastPass, My Last Pass Vault. This displays everything in your vault. The IE buttons just seem to work on via your local files.
DrD48
