Installation failure FF5.0 Win7-64bit
Postby I am 4 wind » Thu Jun 23, 2011 9:30 pm
Extension is not installing in Firefox 5.0, Windows 7-64bit.
Thanks in advance.
I am 4 wind
Re: Installation failure FF5.0 Win7-64bit
Postby jonat » Fri Jun 24, 2011 10:41 am
Works for me on three different systems so far. Use https://rodan.lastpass.com/lp_win.xpi
jonat
Postby Paul Kingtiger » Wed Jul 06, 2011 11:43 am
I'm having a similar problem. Same set up, run the install which completes. Then add the Chrome add-in from the app store and that works great.
But the firefox add-in is disabled with the following message:
However when I installed xmarks via the firefox add-in system on completion it gave me the option to install lastpass which I did, and that works.
So, Steps to Install Lastpass on Firefox 5:
  • Install xmarks add on
  • Restart Browser
  • Complete xmarks installation process
  • Use link to install lastpass
This is tested and works. However you might be able to simply install lastpass via the firefox extension system rather than the lastpass website. I haven't tried it, but I suspect it would work.
[Update] The version firefox installs from the FF extension manager is 1.74 so there you go, ignore the lastpass install and use the one from the firefox extension manager (add-ons) instead
Paul Kingtiger
