Removing unsecured passwords after LastPass installation
Postby leerann » Sun May 01, 2011 12:13 pm
I have installed LastPass on a Windows 7 computer but did not accept to "Remove Unsecure Logins" from my computer when installing. Is there a way that I can delete these unsecured passwords now? Or would I have to reinstall?
leerann
Re: Removing unsecured passwords after LastPass installation
Postby kilgry » Sun May 01, 2011 5:33 pm
I believe the LastPass Importer will do it. (under the lastpass start menu group)
kilgry
Postby leerann » Mon May 02, 2011 1:38 pm
Well, I went to the import feature and wasn't sure what to import from. Most of the passwords are probably in Google Chrome. Thanks for any advice.
leerann
Postby merajulie » Tue Aug 16, 2011 12:04 am
I didn’t come across this type of problems.Before installing lastpass I make sure that I remove unsecure logins. As said by kilgry it is true, we can delete those unsecured logins with the help of lastpass importer, but me too doesn’t know exactly how lastpass importer works. It is better to follow online tutorial in this regards which will really assist you.
merajulie
Postby Israel » Wed Aug 17, 2011 6:17 pm
After running the installer import wizard, we ask you if you want to remove your insecure data (stored passwords).
Israel
Site Admin
Postby dicoz » Sun Dec 30, 2012 4:19 pm
I selected yes on this during set-up but I looked in chrome and all of my logins and passwords are still there. Am I confused as to what this feature "remove all unsecure data" does? :?:
dicoz
Postby rob_newman » Mon Jan 21, 2013 8:24 am
dicoz Wrote:I selected yes on this during set-up but I looked in chrome and all of my logins and passwords are still there. Am I confused as to what this feature "remove all unsecure data" does? :?:
May be it removes stored passwords for unsecure connections and sites?
rob_newman
