IE9 64bit not taking the update
Postby jdcarroll2 » Fri Apr 01, 2011 10:11 am
LastPass works just fine in IE9 32bit but seems to be caught in an endless loop for 64bit. It keeps asking me to install an update, appears to do so, shuts down and then shows a succesful update. As soon as I reopen it again ask me to install the update. Anyone have a fix other than not using 64bit?
Thanks
jd
jdcarroll2
Re: IE9 64bit not taking the update
Postby Israel » Mon Apr 11, 2011 11:38 am
Go here in IE64 and run the installer manually : http://www.lastpass.com/dl
Israel
Site Admin
Postby bjsbiz » Tue May 10, 2011 12:02 pm
I cannot access my vault listing in IE 9. It will accept my log in info, but does not display any of my sites, even if I search a site. I have tried to run the manual installer (http://www.lastpass.com/dl) that's listed in Israel's posted reply but still cannot view my vault sites. I just clicked on the link & agreed to the install. Still cannot see my sites in IE9!! :( Please help! Thx in advance 4 ur help!
bjsbiz
Postby merajulie » Tue Aug 16, 2011 12:05 am
Definitely when you upgrade your browser from IE9 32bits to IE9 64bits you have to compulsory install all the updates required for it, unless you will face same problem. I think updates installed by you seem to be corrupted. Link shared by Israel will definitely help you a lot in overcoming that problem. That link even helped me in solving this problem.
merajulie
Postby Israel » Tue Aug 16, 2011 4:02 pm
Can you make sure you've run all your windows updates?
Israel
Site Admin
