Installer silently fails to install chrome extension
Postby wererogue » Thu Dec 16, 2010 8:02 pm
My chrome version is 8.0.552.224, and I'm running Windows 7 X64
When I try to install the extension directly from either https://chrome.google.com/extensions/de ... egeplioahd or https://chrome.google.com/webstore/deta ... egeplioahd I get the error described in the chromium bug report here: http://code.google.com/p/chromium/issue ... l?id=57370
If I try to install the extension by unpacking it, signing in using the extension doesn't work properly and it seems generally unreliable, including complaining regularly that it can't contact the server.
I believe this is chrome-side bug, but I wanted to report it in case there was a workaround that could be implemented.
wererogue
Users browsing this forum: RBernier and 4 guests
