Updates and also Red bar error
Postby larhome » Sat Oct 02, 2010 1:59 pm
Multiple Problems
Lastpass Error: "An error occurred while attempting to contact the server. Please check
your Internet connection." I get this displayed as a red stripe randomly when I browse
different sites in IE8 which is annoying.
I also checked for updates and it says one is available and I get the message:
"An update is currently downloading, you will be prompted to install when the
download is complete."
However I never did receive any updates.
Clicking TOOLS>ABOUT shows my current version:
LastPass
Version: 1.69.0
Built: Jul 11 2010 12:52:48
Finally Do I need to uninstall 1.69 to get 1.70.1 ? as updates are not working ? What are the correct proceedures ?
larhome
Re: Updates and also Red bar error
Postby msun » Wed Oct 06, 2010 1:57 pm
I had exactly the same issue so I manually installed the current version from the main web site and the issue seems to be resolved with the current 1.70.1 version.
msun
