How do I install LastPass on IE9?
Postby emcwiz » Mon Sep 20, 2010 11:12 pm
Sorry for the simple question, but I have the Last Pass add-on installed and working in Chrome and Firefox, but I recently installed IE9 beta, read through the IE9 posts in this forum, looked around the internets, but I must be getting old, I cannot find how to get that little LastPast icon in IE9...help and old man...thanks.
emcwiz
Re: How do I install LastPass on IE9?
Postby Lars » Mon Sep 20, 2010 11:22 pm
IE9 is a beta release, not yet supported by LastPass.
Lars
Postby brantgurga » Mon Sep 20, 2010 11:44 pm
LastPass is available in IE9 the same way as in IE8. It is there as a toolbar by default. You can also add it to the Command Bar. In IE9 though, the Command Bar is not shown by default so you have to show it. So try right-clicking the toolbars and you'll see an option for LastPass, Command Bar, Favorites Bar, Status Bar. Play with those options as well as the Add or Remove Commands option.
brantgurga
Postby emcwiz » Tue Sep 21, 2010 12:14 am
I appreciate the assistance, but it appears LastPass is not listed or shown in the tool bar, nor in the command bar. When I show the command bar (which works) and right click, there is no LastPass shown at all....hhhmmm sounds like a problem?
emcwiz
Postby brantgurga » Tue Sep 21, 2010 7:31 am
Did you install LastPass before or after Internet Explorer 9 Beta? It's possible that the installer won't install it on IE 9, but if you install it on IE8, then install IE9 Beta, that should work. That was my scenario.
brantgurga
Postby JoeSiegrist » Tue Sep 21, 2010 1:05 pm
IE9 beta Users -- please try our latest prebuild:
https://lastpass.com/lastpasspre.exe or
https://lastpass.com/lastpass_x64pre.exe
This should fix startup time issues, black screen after notification bar, context menu, and errors on the local vault.
We're are still working on website https://lastpass.com/?ac=1 website issues (but that will be fixed server side change) and there is nothing we can do about pinned tabs/apps now.
Postby emcwiz » Tue Sep 21, 2010 5:29 pm
JoeSiegrist...thank you, I ran the 64bit version and WALA the LastPass icon has presented itself within my IE9 beta...you and the team is the gas...
emcwiz
Postby LouNawlins » Tue Sep 21, 2010 9:14 pm
Thanks for the quick update links!
PS. After installing the patches, I viewed the short video and am working on designing a training program for our Boy Scout Council and possibly the National training site and would like to know the program you used to make the video.
Thanks
LouNawlins
Postby lesgatibris » Wed Oct 27, 2010 12:18 pm
Even with the new lastpass.exe, lastpass doesn't work with IE 9
lesgatibris
Postby brantgurga » Wed Oct 27, 2010 5:17 pm
Lesgatibris, are you showing the LastPass toolbar again? IE9 will hide all your toolbars when you install it.
brantgurga
