IMPORTANT : DO NOT USE Google Chrome DEV Channel: It introdu
Postby cjhinton » Tue Aug 24, 2010 12:38 pm
receiving "(IMPORTANT : DO NOT USE Google Chrome DEV Channel: It introduced Chrome bug 52096 which can cause data corruption.)" Is there a update pending. For this problem... I,ve tried to revert back to the Standard of Chrome an get the same warning. Do Not Install? :arrow: :oops:
cjhinton
Re: IMPORTANT : DO NOT USE Google Chrome DEV Channel: It int
Postby Israel » Tue Aug 24, 2010 3:56 pm
If you get the warning you're NOT running the standard version of chrome. Uninstall the dev version and use the official release from www.google.com/chrome
Israel
Site Admin
Postby Israel » Tue Aug 24, 2010 3:57 pm
The update pending is from google - there's nothing wrong with the extension, their Javascript interpreter can't perform complex math correctly.
However, there's no reason to be using the developer version if you don't need to - if you want to be on the 'cutting edge' you can always use the beta.
Israel
Site Admin
