Lastpass prompting to install, but no new version
Postby ccrawford » Tue May 18, 2010 10:17 am
I'm geting the red "an updated lastpass toolbar..." notification, and if I click to install the installer seems to run, but I still get prompted the next time I restart my laptop.
If I choose Lastpass->tools->check for updates, it tells me no updates available. About says I have version 1.68.2 on IE8 on top of Windows 7. Firefox extension also installed.
Any ideas?
ccrawford
Re: Lastpass prompting to install, but no new version
Postby JoeSiegrist » Tue May 18, 2010 10:57 am
I think I may have seen the issue -- can you report if it happens anymore? If so I've added it to one of our testing cases so you shouldn't see it anymore.
Postby ccrawford » Thu May 20, 2010 9:54 am
Still happening. Seems to happen only after a reboot. Will look a little more to see if I can provide additional details.
ccrawford
Postby screenname » Tue Jul 20, 2010 9:00 pm
One of my PC have this problem. The PC is running Winodws 7 with LP 1.69.0 for IE 8, 1.69.1 for Firefox 4 beta 1 and 1.69.1 for Chrome. LastPass works on all these browsers without issue except IE8 keeps display the "An updated Lastpass is available". If I click update, it will go through the motion to update LP but the prompt will show up again after I start up IE8 again.
I have uninstall/install LastPass but the issue remains.
I do not see what trigger the update prompt from showing up?
screenname
Postby JoeSiegrist » Wed Jul 21, 2010 9:13 pm
Bizarre -- I can't see how this could happen. If this is still happening to anyone would like to see the LastPass Icon -> tools -> About screenshot in IE
Postby screenname » Wed Jul 21, 2010 11:15 pm
JoeSiegrist Wrote:Bizarre -- I can't see how this could happen. If this is still happening to anyone would like to see the LastPass Icon -> tools -> About screenshot in IE
See attached. The about screenshot is not superimposed to the update prompt. Other than cropped the image for privacy reason, no modification has been done.
Is there anyway to remove/delete all trace of LastPass? I noticed my preferences are kept across uninstall and install. Can I be one of the registry entry is corrupted?
screenname
Postby Israel » Thu Jul 22, 2010 4:33 pm
Well.. you are running an older version of lastpass. Download and install manually from our website :
http://www.lastpass.com/download
Israel
Site Admin
Postby screenname » Thu Jul 22, 2010 4:47 pm
Israel Wrote:Well.. you are running an older version of lastpass. Download and install manually from our website :
What do you mean I am running an old version? The one I have is 1.69.0 which is the same one at http://www.lastpass.com/download.
Furthermore, if I click LP's icon -> Tools -> check for updates, LP will show I have the latest...
screenname
Postby Israel » Thu Jul 22, 2010 5:08 pm
Sorry, I thought this was Chrome which is at 1.69.3.
Can you try running the installer manually with all web browsers closed?
Israel
Site Admin
Postby screenname » Thu Jul 22, 2010 6:26 pm
I did:
- download lastpass.exe form lastpass.com and save to disk
- uninstall LastPass
- shutdown PC
- power up PC
- install lastpass.exe with all browsers closed
- open IE8, Firefox 4 & Chrome to verify LastPass has been installed correctly
- close IE8, Firefox 4 & Chrome
- open/close IE8 several times and got the update prompt. See attached.
From past experience, it makes no difference if I dismiss the upgrade or allow the upgrade to proceed. Either way, the occurrences of upgrade prompt is random and my rough guess is maybe 25~30% of times I will get the upgrade prompts out of IE8 startup.
screenname
