IE 64 bit
IE 64 bit
Postby wpeters » Fri Feb 27, 2009 3:36 pm
I am using Vista 64 bit. It includes IE 32 and IE 64bit versions. The install set up IE 32 bit version okay, but not IE 64 bit version. Is there any support for IE 64 bit?
wpeters
wpeters
Re: IE 64 bit
Postby JoeSiegrist » Fri Feb 27, 2009 7:03 pm
Re: IE 64 bit
Postby sadaniel » Sat Feb 28, 2009 8:53 am
JoeSiegrist Wrote:http://forums.lastpass.com/viewtopic.php?f=11&t=2379&p=12469#p12469
the zip file is corrupt any other ideas on how to get ie7 64bit to work with lastpass?
sadaniel
Re: IE 64 bit
Postby JoeSiegrist » Sat Feb 28, 2009 10:43 am
The zip file works for me... What is telling you it's corrupt?
Re: IE 64 bit
Postby sadaniel » Sat Feb 28, 2009 11:04 am
I am using winrar and it gives me a message that it is corrupt..it will open and show a directory with a .dll in it but I get the message and it won't allow me to extract the file...
I have also used 7-zip and get the same error...
sadaniel
Re: IE 64 bit
Postby JoeSiegrist » Sat Feb 28, 2009 11:34 am
Is the file 1.7M in size? I'm able to extract using winrar and 7-zip without issue
Re: IE 64 bit
Postby jay09 » Mon Sep 07, 2009 9:40 am
There's probably something wrong with your winrar if you can't unzip it.
Regards,
Jay
Pret travaux
jay09
