Install error
Install error
Postby 5415896 » Sun May 19, 2019 5:58 pm
Hello, I download https://download.cloud.lastpass.com/win ... taller.exe and I install on Windows 10, but I receive error, look screanshots https://prnt.sc/nqokmh , https://prnt.sc/nqokos , https://prnt.sc/nqokqg , can you help? Thank you.
5415896
Re: Install error
Postby mlove679 » Sun Jun 09, 2019 5:59 pm
I second that. I first tried using the .msi download from the Admin view but got a "Powershell 1.0 is needed" error which was funny cause I was running the install from powershell.
Then I did the same thing as you and downloaded the installer.exe and got that 1603 error that you reference.
I don't get it. This used to work without any issues and now all of a sudden it's failing. I'm wondering if it's a Windows 10 update or something that is causing this.
mlove679
