Silent install possible?
Postby llamathumper » Fri Apr 19, 2019 1:20 pm
Hi,
I am creating a Win10 install and would like to be able to install LastPass silently. How can I do this? It seems this was possible previously but is now limited to LastPass Enterprise? Is that correct? If not, what switches can I use with which installer?
Many thanks in advance for any tips.
llamathumper
Re: Silent install possible?
Postby jpenny84 » Fri Apr 19, 2019 2:04 pm
I believe that they only offer MSI files through the enterprise dashboard. You would need an enterprise subscription to access those.
jpenny84
Postby llamathumper » Fri Apr 19, 2019 3:26 pm
Thanks. Understand should also be possible with .exe files, as long as the functionality is in-built (no idea how, all I'm saying is that I can routinely silent-install also with .exe files).
But anyhow thank you for the answer.
llamathumper
