Add to LastPass on entry?
Postby CWBillow » Wed Apr 10, 2019 9:02 pm
If I am just building my list, and I go to a site and manually enter my info, how do I get lastpass to save it?
CWBillow
Re: Add to LastPass on entry?
Postby jonat » Sun Apr 14, 2019 2:22 pm
In most cases LastPass will do this automatically, but the way some sites prevents it from doing so. You can enter your login info, and before you submit the form, click on the LastPass toolbar icon and select Add Item > Save All Entered Data. This will create a vault entry for you. Then you can log in.
jonat
