Edge and 4.21
Edge and 4.21
Postby tmckay475 » Thu Jan 03, 2019 12:42 pm
Does the new release not work with Edge?
tmckay475
Re: Edge and 4.21
Postby sanctempdyra712 » Fri Jan 04, 2019 7:09 am
Searching for the same. Do you find any solution??
sanctempdyra712
Re: Edge and 4.21
Postby tmckay475 » Fri Jan 04, 2019 9:39 pm
No. Not yet.
tmckay475
Re: Edge and 4.21
Postby jpenny84 » Sat Jan 05, 2019 11:38 am
As long as it works, I wouldn't be too worried about version mismatches.
jpenny84
Re: Edge and 4.21
Postby tmckay475 » Mon Jan 07, 2019 12:25 am
The problem is that the preferences don't work ( LastPass logs off if you set any preferences) in 4.19 and it's supposedly corrected in 4,21. It's an important fix for Edge users.
tmckay475
Re: Edge and 4.21
Postby jupitalita8723 » Wed Feb 13, 2019 3:18 am
Yes, I think the v4.21 is now compatible with Edge.
jupitalita8723
