Removed LP Free from MS Edge but full LP won't install
Postby notasaintinca » Wed Dec 26, 2018 11:11 am
Hello,
I am hoping that there is a quick and straightforward resolution for this...
I originally used the LP Free browser extension for MS Edge and it worked fine minus firewall/connectivity hurdles. I decided to go ahead and pay for full LP and downloaded the app from the MS Store but did not remove the LP Free browser extension from MS Edge.
I have been having intermittent issues lately with saving password changes and figured I should remove the LP Free and install the full version. Unfortunately, after removing the LP Free I do not see any mechanism for adding the full LP extension to the browser.
Any ideas?
TIA,
-m
notasaintinca
Re: Removed LP Free from MS Edge but full LP won't install
Postby jpenny84 » Wed Dec 26, 2018 11:57 am
Both free and paid customers use the exact same extensions. More features are simply enabled for premium users.
jpenny84
Postby notasaintinca » Wed Dec 26, 2018 1:42 pm
OK, Thanks. Seems I'm having other issues then. I will have to monitor and post when I see a pattern.
Cheers!
notasaintinca
