Edge Manual Install ?
Postby ustewjt9696 » Thu Aug 02, 2018 8:27 am
Employer has blocked the MS Store in Edge. Is there a manual download/install option for Edge?
ustewjt9696
Re: Edge Manual Install ?
Postby justahockeyfan805 » Fri Aug 03, 2018 11:36 am
It can be done using a program called "Fiddler 4" on a PC that has Microsoft Store access. When you download the app from the PC that has store access and Fiddler 4 installed, Fiddler will show you the hidden URL link that gets generated for the actual app download. This link is only valid for a few min, so you have to copy the URL link and paste it to your work PC that has the store blocked. Then you can download the app without going through microsoft store. The download will be a .apk file that you can retain to restore the app again if you ever remove it or lose it. If you wait too long, the URL link will become invalid. Now, if you already have the app installed on your PC that has store access, then uninstall the app, launch Fiddler, then download the app again from the store.
My work too blocks the store access, so I used the process above to download and reinstall all the store apps (.apk files) I needed for my Edge browser :D
Here is a great tutorial on how this is done https://www.windowscentral.com/how-inst ... osoft-edge
justahockeyfan805
Postby shanepierce1 » Sat Aug 18, 2018 5:27 pm
Was finding a way to install on microsoft edge but wasnt so fruitful. Will try this method and update this thread. Thanks in advance.
shanepierce1
Postby callmejacklogan481 » Sat Oct 06, 2018 12:06 pm
You have to copy the URL link and paste it to your work PC that has the store blocked. Then you can download the app without going through microsoft store. The download will be a .apk file that you can retain to restore the app again if you ever remove it or lose it. If you wait too long, the URL link will become invalid.
callmejacklogan481
