installing binary component on Windows 10
Postby bluebee59 » Mon Mar 19, 2018 12:10 pm
Hello to all members,
I have tried to install the binary component today (I wanted to add an attachment) : Windows 10 first asks me if I really want to install it because it is not an application from Windows store and if I really want to install it anyway. I said I wanted to install it. Then I got this message :
Lastpass_exeX64 Warning / Locale 'Fiji' not supported by OS
I am not an expert at computing, so I postponed the installation until one of you clearly explains to me what I should do.
Thank you for your help.
bluebee59
Re: installing binary component on Windows 10
Postby davidostfarley696 » Tue Apr 17, 2018 3:11 am
I'm afraid that I won't have an explanation that would suit you, and the same problem I have with 64 bit ... I'm waiting for help too)
davidostfarley696
Postby SGO » Tue Jun 19, 2018 7:35 am
Would installing https://lastpass.com/lastpass_x64pre.exe fix this issue for you?
SGO
Postby Hubmacfan » Wed Jun 20, 2018 8:29 am
@bluebee59, do you live in Fiji. It sounds like you have that set as a locale on your computer.
Hubmacfan
Postby ariah » Wed Jul 11, 2018 9:41 am
Did you find the solution to your problem? I have the same problem and I have not found the answer.
ariah
Postby ariah » Thu Jul 12, 2018 4:26 pm
I do not see any solution to this problem, it remains an unresolved problem for me too.
ariah
Postby ariah » Sun Jul 15, 2018 4:07 pm
ariah
Postby bernardsims725 » Fri Aug 24, 2018 10:44 am
[quote
Post by ariah » Sun Jul 15, 2018 4:07 pm
I do not see any solution to this problem, it remains an unresolved problem for me too.][/quote]
Any solution ?
bernardsims725
Postby michael5024 » Sun Sep 02, 2018 10:54 am
Installing windows 10 components is sometimes weird.
Perhaps this is your solution
https://lastpass.com/support.php?cmd=showfaq&id=5576
michael5024
