Edge install??
Edge install??
Postby dc777 » Fri Mar 09, 2018 12:23 pm
I read where LastPass now worked with Edge. I have used it with IE and this browser is pretty much a dog abandoned by MS as Edge is now their defacto browser. So I renewed LastPass. I installed the LastPass App, but that is not very useful as a browser. I don't see instructions anywhere on how to install in Edge. Can someone point me in the right direction? Thanks!
dc777
Re: Edge install??
Postby jpenny84 » Fri Mar 09, 2018 12:50 pm
There is a dedicated extension store for that browser.
jpenny84
Re: Edge install??
Postby dc777 » Sat Mar 10, 2018 11:13 am
Hi jpenny84, I truly appreciate the reply. I'm a newb, would you please point me in the direction to get/install this "extension"? Thanks!
dc777
Re: Edge install??
Postby dc777 » Sat Mar 10, 2018 11:17 am
Oh, sorry - I found it and I'm installing now. Thanks again!
dc777
Re: Edge install??
Postby lawridersc52 » Sun Sep 02, 2018 12:57 pm
Where did you find the extension? My Edge has stopped working. It was working for a couple of months and has just stopped.
lawridersc52
Re: Edge install??
Postby jpenny84 » Sun Sep 02, 2018 5:44 pm
lawridersc52 Wrote:Where did you find the extension? My Edge has stopped working. It was working for a couple of months and has just stopped.
You would install it from the Microsoft Store:
https://www.microsoft.com/en-us/store/c ... ns/p?rtc=1
jpenny84
Re: Edge install??
Postby Boxer1292 » Sat Feb 02, 2019 10:21 am
I've been trying to install LastPass for MS Edge from the MS Store - it downloads, but won't install - giving me an error code:- 0x80072F8F.
A google search tells me this refers to a 'time and date' issue when trying to activate W10!
I've been using W10 Pro on this m/c for 4 years now, so I should think it's been activated, and the time and date are correct.
Have just downloaded and installed the latest update from MS - no difference.
Can anyone figure this one out please?
Boxer1292
Re: Edge install??
Postby Boxer1292 » Sun Feb 03, 2019 2:43 pm
[quote="Boxer1292"]I've been trying to install LastPass for MS Edge from the MS Store - it downloads, but won't install - giving me an error code:- 0x80072F8F.
I get the same problem and error code whatever app I try to download and install from the Microsoft Store.
Boxer1292
Re: Edge install??
Postby jpenny84 » Sun Feb 03, 2019 3:57 pm
Boxer1292 Wrote:
Boxer1292 Wrote:I've been trying to install LastPass for MS Edge from the MS Store - it downloads, but won't install - giving me an error code:- 0x80072F8F.
This sounds like a Microsoft problem. I would reach out to their support channels. They have a helpdesk article for activation errors: '
https://support.microsoft.com/en-us/hel ... ion-errors
jpenny84
Re: Edge install??
Postby Boxer1292 » Mon Feb 04, 2019 9:13 am
Thanks for your reply - I'll try Microsoft Support and let you know if I get anywhere.
Boxer1292
