Encrypted zip for lastpass.exe
Postby derricktan730 » Mon Dec 18, 2017 7:51 pm
Hi all,
My company firewall block all unknown exe file and am just wondering if there's a way I can get the installer in a tar.gz or even in an encrypted zip format.
Thanks
derricktan730
Re: Encrypted zip for lastpass.exe
Postby jonat » Mon Dec 18, 2017 9:41 pm
I suppose you could create it at home, or just copy the EXE to a USB drive, but do you really want to violate your employer's security policies? Note that in some browsers you can add extensions without running an installer.
jonat
Postby zimou13 » Tue Mar 27, 2018 8:06 am
Since all sensitive data is encrypted locally on your computer with the key that only you know before it is sent to LastPass, you can store your most sensitive data with the knowledge that is it is completely safe. Just like all of your LastPass data, your Secure Notes will be available from any location with your LastPass Vault.
zimou13
Postby davidostfarley696 » Tue Apr 17, 2018 3:08 am
Following the advice of the programmer, I changed the antivirus settings 360 I-Security in my case and updated the LastPass, that's all/ Although, not entirely, I still have a universal viewer and zip. it recognizes automatically
davidostfarley696
Postby zimou13 » Fri Apr 27, 2018 5:44 pm
Spammer
zimou13
