Last Pass Login screen in Edge
Postby greg88220 » Tue Jul 25, 2017 2:18 am
Hi,
I want to get rid of the Last Pass login screen which opens automatically when I start up Edge. I would prefer that Edge started and if I needed to go into Last Pass that I did this by clicking the three black dots and then manually logging in?
I have disabled the two Last Pass entries in the Windows start up file but that seems to make no difference. Can you tell me how to overcome this problem?
greg88220
Re: Last Pass Login screen in Edge
Postby hope805529 » Mon Jul 31, 2017 6:33 pm
Hi, I am also searching for the answer to this exact question. I have tried the same thing you have. Anyone out there that can help?
hope805529
Postby Gracie4 » Sat Aug 05, 2017 11:18 am
I haven't found an answer, but I too have the same problem. It only happens when I open the first instance of EDGE. if one instance is open and I open a second instance, I don't get the Last Pass auto login screen.
Gracie4
Postby hope805529 » Thu Aug 17, 2017 10:08 am
Thanks Gracie4. Trying to keep this alive in case a solution is found. Very annoying when I have my home page set to something totally different.
hope805529
