MS Edge extension not loading - Manifest error !READ!
Postby Mysefl » Sat Jun 10, 2017 1:24 pm
I searched this error and based on what is in this forum re-installed Lastpass app from a post here (https://www.microsoft.com/en-us/store/p ... zdncrfj3qk).
1. Installing the app works, but no extension shows.
2. From Win Store clicking Launch opens the app and I can login correctly. BUT still extension does not show.
3. TRying to sideload the extension from the WindowsApps folder under /Program Files/WindowsApps/Lastpass.LastPassFreePasswordManager.4.1....../Extension gives the following error
"Manifest parsing error: Invalid value for "key" field"
Can this please be fixed.
4. Even after complete reset - COMPLETE -of Edge browser the app installs but extension does not load.
5. Sideloading is done after enabling 'developer' mode in Edge using about:flags.
Fix needed !
Mysefl
Re: MS Edge extension not loading - Manifest error !READ!
Postby Mysefl » Sun Jun 11, 2017 10:20 pm
Really? No ideas? The error seems quite specific.
Do reply!
Mysefl
Postby NaveedLP » Wed Jul 05, 2017 1:07 am
Seems like a common issue with Edge not specific to LastPass. Check this FAQ https://docs.microsoft.com/en-us/micros ... leshooting
NaveedLP
Postby dewp » Tue Jul 11, 2017 2:10 pm
Edit the manifest.json file.
Look for the field "key" and remove that entire line.
If you try adding the extension again, it should load properly.
dewp
Postby dewp » Tue Jul 11, 2017 2:11 pm
dewp
