Windows 10 desktop app and Chrome app
Postby murrayotl007484 » Wed Jun 15, 2016 8:17 am
Hello
I have Lastpass installed on Chrome and downloaded Windows 10 64 bit version. When using on Windows it closes Chrome app, and the opposite, if using Chrome knocks off Windows version. Is this the normal working procedure?
Thanks, John
murrayotl007484
Re: Windows 10 desktop app and Chrome app
Postby dmitrijLP » Sun Jun 26, 2016 7:57 pm
Hi there,
If you uncheck the "Share Login State Between Other Browsers" does that help resolve this behavior?
https://lastpass.com/support.php?cmd=showfaq&id=7636
dmitrijLP
Postby murrayotl007484 » Mon Jun 27, 2016 7:10 am
Thank You for Response!
No dmitiiJP I get knock off Windows 10 LastPass when using it on Chrome,and when using in Windows knocks out Chrome LastPass. I unchecked your suggestion and still happening. I have to enter password every time.
Thanks, John
murrayotl007484
Postby dmitrijLP » Mon Jun 27, 2016 3:55 pm
murrayotl007484 Wrote:Thank You for Response!
Thanks, John
Are you using your mobile device in between? Please try to click on your LastPass icon --> My LastPass Vault --> Account Settings --> Show Advanced Settings --> uncheck "Auto-Logoff Other Devices" and click on the Update button to apply the new change, then check again.
dmitrijLP
Postby murrayotl007484 » Tue Jun 28, 2016 11:06 am
Ok dmitrijLP It's done seems to be working now.
Thanks for you help,
John
murrayotl007484
