No buttons on the installer
Postby sroberts867 » Tue Apr 12, 2016 10:27 pm
I can't install last pass because the buttons don;t show up on the installer. I'm at the window that says it found passwords and it's going to copy them up. the window is very small and won't resize so I can't see much of the list of passwords or the buttons to click. very odd
Surface Book 4 with latest Windows 10 updates using the lastpass_x64.exe installer that I just downloaded. I restarted my computer and attempted a second time with the same results
Any ideas?
sroberts867
Re: No buttons on the installer
Postby jpenny84 » Tue Apr 12, 2016 11:12 pm
Go into your display properties and try temporarily reducing screen scaling to 100%.
jpenny84
Postby sroberts867 » Wed Apr 13, 2016 1:25 am
That did help the first couple of installer prompts however the prompt that shows the passwords that it found on my system is still not resizable and basically useless. No button and I can only see part of one of the listed passwords without scrolling sideways. because it is so small.
sroberts867
Postby dmitrijLP » Fri Apr 15, 2016 5:49 am
Please try using the following installer and if the issue will still persist share a screenshot from your view - https://lastpass.com/lastpass_x64pre.exe
dmitrijLP
