Can't complete installation of 4.0
Postby greenspeed » Tue Jan 05, 2016 3:37 pm
I have a Lenovo Yoga 3, running Windows 10. When I try to upgrade LastPass I get stuck on a poorly-formatted dialog box where the text font is so large it pushes the response buttons outside the edges of the non-resizeable dialog box.
greenspeed
Re: Can't complete installation of 4.0
Postby jpenny84 » Tue Jan 05, 2016 4:26 pm
greenspeed Wrote:I have a Lenovo Yoga 3, running Windows 10. When I try to upgrade LastPass I get stuck on a poorly-formatted dialog box where the text font is so large it pushes the response buttons outside the edges of the non-resizeable dialog box.
Try going into your display settings and temporarily adjusting the screen scaling to 100%.
jpenny84
Postby cajunlibra79 » Wed Jan 06, 2016 12:00 am
I'm noticing the same rendering issues with LastPass App for Windows 10. The software is pretty unusable. It's similar to going to a website that doesn't read the HTML correctly and you see tags.
cajunlibra79
Postby jpenny84 » Wed Jan 06, 2016 12:32 am
cajunlibra79 Wrote:I'm noticing the same rendering issues with LastPass App for Windows 10. The software is pretty unusable. It's similar to going to a website that doesn't read the HTML correctly and you see tags.
Have you tried setting your screen scaling to 100% in your display settings?
jpenny84
Postby SouthRider » Wed Jan 06, 2016 8:29 am
I have the same problem on a surface pro 3 using firefox. Scaling in firefox is set to 100%. Windows display setting is 175%, but changing it to 100% doesn't help - it just makes the lastpass window smaller.
I have tried just randomly hitting tab and enter - no luck. It only goes back to the login screen. Now lastpass 3.2 is no longer on my toolbar.
This "great" new version has managed to disable itself completely :!:
SouthRider
