Lastpass freezes when using Firefox
Postby christos31210 » Fri Dec 04, 2015 5:27 am
Hi I am using Firefox Developer 44.0a2 (2015-12-03), and every time I try to click on the * icon to show lastpass list off accounts the whole page froze and I have to restart Firefox to fix this.
Is there a way to fix the add-on? It makes FF unusable!
Thanks
christos31210
Re: Lastpass freezes when using Firefox
Postby chuck301 » Fri Dec 04, 2015 4:23 pm
I'm having the same problem with Developer, and in 43.0b8 last pass will not fill in forms or passwords.
chuck301
Postby jpenny84 » Fri Dec 04, 2015 4:34 pm
LastPass officially only supports stable browser builds. You may have luck disabling the multiprocess component.
jpenny84
Postby GASOLINE » Wed Dec 23, 2015 9:09 am
jpenny84 Wrote:LastPass officially only supports stable browser builds. You may have luck disabling the multiprocess component.
I had the same problem for a while, so I almost wanted to ditch Lastpass and/or FIREFOX.
However, swithcing off Multiprocess in FF Dev (Thanks a lot) solved all the problems. Everythings running smoothly now.
GASOLINE
