by luddev » Thu Oct 22, 2015 9:53 pm
I have the same issue. The issue being that nothing happens when clicking the right most lastpass button, no matter what setting. Uninstalled lastpass recently since I saw there was a new version, and I hadn't noticed lastpass prompting for any updates on its own (if lastpass doesn't do this, please add the function). Downloaded the new version, installed and this issue appears.
Also I know this has been said before in other posts but I'm going to do so anyway: You need to sort out the version numbers, it is very confusing, I'm thinking I might not have needed to install the new version because maybe I already had it, right?
before I made, what I thought was an update, I checked the version number of the lastpass.exe, which was lower then the version number on the DL site, hence I proceeded with the DL only to find out I still get the same version number...
