Plug-In install/uninstall
Postby net4ward » Sat Aug 30, 2008 10:01 am
If I previously installed lastpass and selected to only install the FF plug-in, is there anything other ran rerunning the install to add the IE plug-in?
Also, how do you conversly uninstall a plug-in? Can that be done by unselecting a plug-in?
I know I can use the FireFox Add-on interface to disable and/or remove the FF plug-in. How would I uninstall the IE plug-in?
net4ward
Re: Plug-In install/uninstall
Postby JoeSiegrist » Sun Aug 31, 2008 8:47 am
The easiest way is to uninstall, then go through the installer and reinstall just the plugin you want...
If you have the FF plugin, but not IE plugin, (or vice-versa) it's safe to rerun the installer and add the one you want.
Joe
