Hi, I'm having some trouble importing my data from KeePass. First off, I'm on Linux, so I'm using KeePassX, though I'm not sure the procedure would be any different. But I followed the instructions exactly as they were listed for KeePass, and I get nothing. It just says "Found 0 sites or could not parse data". Maybe KeePassX is different? If so, is there some sort of workaround for importing my data?
Thanks,
John
